super s cluster into 1.0
jabran200
Where do you add the wire from the dizzy? I searched but only found the guide that shows to change the mileage and thats it.
All Micra's have the cable behind the clocks, except for the L and Tropic I believe. Whereas all the others have it, the LX for example definatly did cos I know someone who had the cables there.
I'm sure it's just lying there and you put it in a pin or something? Someone should know.
any howto or guide? As I really need this, In first gear I dont even realise I am hitting the limiter sometimes, I have a tach but its not the same.
