sr20 guide?
does anyone have a guide or tips on how to put a sr20det red top from an nissan pulsar gtir in to an k11? what kind of gear box do i need? how much shorter must the drive axels be? how much do i need to move the engine mounts? how is the wiring? do i need to modify the gear linkages? and in what way?
You probably won't get a definitive answer... It's not an easy job, if you're not able to measure or check it all yourself, the chances are you'll struggle.
Lots of stuff needs changing, chassis needs notching etc
