sr20 conversion help please
micra gt
hi im doing a sr20 conversion on my k11 ive got engine gearbox in all wiring done it starts only help i need is speedo im using micra clocks but ive got almera wiring loom split into micras loom i need to no is there a speedo drive i can use on the almera gearbox to connect to the speedo cable to use my micra clocks as the speedo drive on the almera is electrical if there is what car can i get it from i would be greatfull for any help and will post pics up soon as i can
cheers andy
You should be able to remove the leccy speedo drive and fit a cable driven one as ive done it on my cg13 twice now. So long as both gearboxes are coded the same and the difference being the speedo drives :)
ive removed both of them but there different in size was hoping there would be a sr20 with cable driven speedo so i can use the drive from on to connect to my micra cable car is getting there now only thing left is to sort speedo and drive shafts hubs sorted and just little cleaning up
