Jamie R Mar 20, 2014 #1 Is there I can remove these and will it leave holes/a long indentation? Its on a Micra inspiration Attachments 1395336410043.jpg 24.1 KB · Views: 218
Magpie42 Actual Magpie. Mar 20, 2014 #2 Try pulling the edge of one up and having a look underneath... they're probably just stuck on with wasp spit or something...
Low Rider Poindexter Founding Member Moderator Club Member Mar 20, 2014 #4 They're stuck on with foam adhesive strips.
Low Rider Poindexter Founding Member Moderator Club Member Mar 20, 2014 #6 Jamie R said: Do there removable! However, is there an indentation underneath them? Click to expand... No just straight bodywork, no indentations or mounting holes. You will likely see a difference in paint finish though, as the paint under them won't have seen the light of day since it was built, so no scratches, oxidation etc.
OP OP Jamie R Mar 20, 2014 #7 Hmm, maybe it would be a bad idea then to remove them, what's your opinion?
Magpie42 Actual Magpie. Mar 20, 2014 #8 Depends on how good the rest of your paint is...if it's really good, it might just clean and polish up... Sent from the Magpie's magical nest using Tapatalk
OP OP Jamie R Mar 20, 2014 #9 In that case then, can I put then back on after or will they never be in quite the right place?
