fair enough, but if you are cornering enough to make the back end loose traction then what is to stop the front doing the same? when wheels are left to spin freely, they have no reason to loose traction unless you are cornering stupidly fast. for example if you loose traction, the quickest way to regain it is by dropping the clutch. the back of the car wont over take you if it has traction which it wont if you try braking (as we know braking on a corner is a bad idea in general) and yea you would have more braking performance from all 4 wheels but the micra is so small and light it doesn't need it. a set of skyline brakes on the front of a micra and i doubt they would ever get hot.
of course you would still have the handbrake so handbrake turns would still be possible
also all cars have smaller brakes at the back and that is for a reason, it can be pretty scary when the back locks first. i removed everything from the back of my micra and the bias was out and when ever i braked down hill the back would lock and just swing out, making the car veer to one side, very very scary. i have had the brakes adjusted so they do practically nothing and then all that happens is the back end follows the front like it should.
there is only two ways the back end would swing out, the back brakes locking before the fronts, which happens when there is less traction, OR when cornering too fast. either way both situations its not the lack of brakes that is the problem its either going too fast or braking too much,
and about tail braking, how would you use it? other than braking with the handbrake? i know it could be useful to those who really know how to drive, not of course for the average person, but you cant have more braking at the back than the front without using the handbrake, and like i said if you disable the back brakes, you still have the handbrake, (if you just lock the fluid lines)
you both make very good points, but i still think that back brakes can cause more problems than they solve, and a good set of front tires and brakes are all you need for braking, and then some wide tires at the back and maybe a spoiler for some down force to make sure that they don't loose traction.
i have driven some towing loads, where the trailer weighs more than the towing vehicle and has no brakes! totally illegal but it was an emergency, and even in those cases the front brakes were enough, there wasn't any jack knifing etc
basically i think that if your back end is loosing traction and needs to be braked then its driving style not the car which is the problem. at least in a micra anyway
