Just below the rubber cover inside the boot itself. The wire is so tight I had to start unplugging wires inside the boot lid and feeding them back through in order to solder them! Luckily I remembered to tie string at the end and in order to pull them back through after some heavy duty heat shrink ensured the problem will never happen again!
