D davecullen6 Jun 4, 2016 #1 hi, what is right kind of plug socket I need to remove plugs, seems very recessed? never actually changed a set on a micra as always had it serviced, but trying to keep costs at minimum on this one , thanks dave
Agent_Sm1th Jun 6, 2016 #2 You'll need the smaller 10mm plug socket. Most good socket sets have both the 10mm and 14mm ones in usually.
OP OP D davecullen6 Jun 6, 2016 #3 Agent_Sm1th said: You'll need the smaller 10mm plug socket. Most good socket sets have both the 10mm and 14mm ones in usually. Click to expand... thanks for that; with a long extension bar on it presumably to reach down to the socket in the cylinder head?
OP OP D davecullen6 Jun 6, 2016 #5 thanks, I'm pretty sure I don't have a 10mm plug socket so will drop by Halfords
