removal of CV joint axle nut
Hi Guys,Have any of you tried the different ways of removing the cv joint axle nut as shown on youtube.? That is without the use of a impact wrench or any power tools. One idea is to use a trolly jack and a breaker bar+correct socket, so instead of using a extra tube for the leverage you use the trolly jack under the handle and jack it up making sure that you are undoing the nut & spray it with WD40 first + remove the split pin. The youtube show that this method is easier the trying to do it by hand & as I'm not a strong ? person I'll try this way. Yours peter0003
Breaker bar (and more porridge) enough for me any time I've taken the hub nut off. Or long pipe extension and average male on the end of it bouncing up and down never fails.
