Rear fog lamp works when indicator on.
Hi my rear fog lamp only works when i switch on and put the stalk in the right indicator position.I was going to the scrappie for a replace stalk but is this a common fault the switch works only in that position sounds like a connection problem in the colume.Any one had a similar fault all the other lights works on the stalk thanks in advance.
