It has an anti tamper cap over it which can only be removed by cutting it off in such a way that you don't damage the adjusting screw itself. The mixture is set by the factory when the car is built and should never need to be altered, hence the anti-tamper cap. If the car runs fine then it is fine and shouldn't be disturbed.
If the car is not running fine then i would reccomend checking the condition of the vaccum hoses, as any leaks would cause an over-lean mixture.
Also check that the bi-metal switch (the valve with an orange dot on it) inside the airbox, to make sure that it isn't stuck open. The bi-metal switch opens when the engine gets above a certain temp and weakens the mixture slightly in order to prevent the engine from over heating.
