Micra 93 preface cluster wring diagram wanted
Am looking for a cluster wiring dia for my cluster I have 3 plugs on mines think they all same, but I need to pin point each wires I found this but not sure if they all same ? Eye to eye I think @frank
can't afford a cross member so just made a removable one and painted it, and welded with arc weld came out strong and mean
How hard is it to move the fuel lines to better place ? I want the tank normal place just move the lines over 5 inch over left or right ? Do I need heater in the car as I don't need one, many wires aswell to wire ? @frank do u have a heater in yours
am trying to find which theses wires feed into ? Looked on manual but I think there is Diffrent colour codes for each Micra as I know,
I was tracing green/red wire which goes to Ecu connector back into the heater control but where should the end go into live+ ?
Orange/black wire I traced it goes from Ecu connector then into the gauge but don't no if I can add this on live or coolant ? @frank would u know where theses come from
