This is an archive of the old Blogs system from the previous software. If you would like your blog entries moving/merging into the relevant forum/thread, please PM James.
These blogs are READ ONLY. Replies CANNOT be made.
Again; same head, therefore everything on & inside are identical to the 1.0l. The only differance between the 1.0L and the 1.2 is that the 1.2 has a taller block and a longer piston travel.
The 1.2 carb is different, in that the jets are smaller than the 1.0l. The standard non-ecu 1.2 carbs are few and far between as the majority of 1.2's were fitted with an electronic carb and cat setup. The 1.0l carb can be used on the 1.2 and works very well.
If you were to put a 1.2 carb on a 1.0l i am pretty sure you would lose some power, since the 1.2 carb is fitted with smaller jets than the 1.0l.
Hope that helps.
