Looking for build advice ?
So I have been greatly thinking about doing some kind of build on my my micra but not sure what to go for I was thinking using the CG10DE block but add some 1.3 internals new clutch all them bits ... but then I think maybe full swap CG13DE or 1.5 almera engine in told would fit but I would like some insight as I lack experience and this would all be a learning process, if anyone would like to share there builds too that be sweet always up for seeing what you guys got :cool:
Hi guys I have 1 of those dreaded 03 plate k12 engine ... Starched chain
Can I bin this engine and run my old k11
1.3 dizzy engine. Non chip key
And would this engine fit the k12 cable driven gearbox. Thanks in advance darren
If you lack experience then just swap your current 1.0 for either a cg13 or cga3 (depending on your ignition type)
Thanks for the insight man I'll look into it find out my ignition type but when I do what ignition type should I have ? And I have a few mates some with not mechanical experience than others so hopefully all goes well once funds happen hehe
