Looking for Advice
CMF_dmac
Hey Guys,
I have a 95 super s, which i dont drive too much anymore as i have a company car...
I want to look into making some modifications, and want some thoughts on what i would need to do to not only get it looking good, (eg wheels, lowering) but get the beast moving quicker as well!
Its pretty stock at moment, and how much would i need to spend?
dmac
CMF_Brendon
how much you want to spend depends on the performance and looks that you want.
first figure out what you want to achieve from the car.eg how much power you want and then what look you want for the car then go from there.
there is no limit to how much you could possibly spend.
for wheels, suspension plus exhaust and headers air intake up the fuel pressure maybe looking at somewhere around 2000 and up. say 700 on wheels and tyres and 300 for lowering then some more on suspension then allow or 700 for exhaust and headers. then 150 on fuel pressure regulator and then few hundred left over for the miscelaneous items.
if you want to go turbo. say from about $6000 and then just goes up from there
CMF_Yom
There's lot of things you can do...
-Whiteline swaybars, suspension, alignment kits
-Extractors (if you don't have aircon that is)
-2" Exhaust
-Modified air intake
-Pulsar brakes
-Power steering (if you don't already have it)
-Weight loss (rear seat and trim removal, etc.)
-Lightweight flywheel & 'heavy duty' clutch
-Cams
-Little things like spark plugs, spark leads, O2 sensor, filters, fancy oils, etc.
-LIGHTWEIGHT RIMS (I can't stress this enough, heavy fancy-pants chrome rims WILL slow you down)
Basically money is your only limit!
