newbie looking for advice/help.
hi i,ve just purchased a 1995 micra Mauritius 1.0L 16v as a second car for work and the odd trip fishing :)
it handles like a boat but already thinking of the alto springs and corsa rear shocks. but first i want to get it running better as it starts on the button when cold but struggles when its hot could this be a temp sensor or auto choke. any advice would be much appreciated.
cheers
anyone in the micra world............
Hello swainer. Yup a few popping in now and again, just go on the search function to find help with your problem buddy.
A few others have had this niggle when starting from warm......seems to be fixed by messing around with the wax stat.....idle control.
hi davyboy cheers for reply been using the search and found sum bits on waxstat and also the solder in throttle body so hopefully that sorts it. then
clear out first cat then make a decat pipe for second then sort suspension.
