Look what...
...just arrived at my local. I'll have the throttle body off of the white one, please, and the flywheel from the silver one if I am correct in assuming that it's a couple of kilos lighter than my 1.3L one, and, that an Almera pressure plate will bolt right on to it.
yes thats why a 1.0 with decent cams and inlet/ exhaust mods is surprisingly quick, its got the same breathing capabilities as a 1.3, ie valve sizes, ports, throttle body etc, but is a rev happy short stroker with a lighter clutch/flywheel
dunno bout that craig, my misses bog standard 95 1.0 has l/ratio diff, and my 93 1.0 micra dot has a h/ratio diff ??????
i'll have the indicator wiring out of the wings please :D
Assume you mean the fronts, but which one? White or silver, or does it matter? If you are dead serious I can probably work something out. Neither car has been passed for trashing yet. Should be a matter of days.
S
