Knocking from front wheel
wehey
Hiya all.
I wonder if someone could help to diagnose a problem for me.
I have a knocking sound coming from the Nearside front wheel when on full right lock.
Also a slight sound coming from the same wheel when going slowly in 1st and on/off the throttle?
I would presume its a worn cv joint but need to be sure before attacking it with spanners.
Thanks in advance :)
Sounds like a CV exactly as you say. I checked mine out when I had this issue and I saw the gaiter had perished and had no grease hence the wear causing knocking.
I'd say CV.
Mine has been knocking when turning right now for 18months. I wouldn't worry unless it's severe.
My boots are fine and all greased, it knocks from the lows.
ive got this really badly....... the knocking i mean. i wasnt worried about it until now, as my last micra did it for 2 years without issue, but now.....................
