deNs WROTE:
"Hub adaptors are nothing unusual, but you're better off buying the right offset wheels first off rather than comprimising and going for spacers. If you go for cheap hub adaptors/spacers you could end up paying a hefty price if they fail on you.<BR><BR>I've seen plenty of low offset original RS wantas up for sale in 13" and 14".. they're not that uncommon.
<BR><BR>Edit: Also, don't know why you mention AE86 folk wanting them. AE86 = 4x114.3 - hub adaptors are a bad way of getting the right PCD and yes, if you go with a set that's 4x114.3 then they'll inevitably be a RWD offset, and once you use hub adaptors it will space that out so much that you'll likely be in the negative offset range, and even flares won't help you there probably.<BR><BR>---dens
