K14 0.9ig-t servicing
Today was the first service at home for the K14 nice and straightforward just a oil and filter today. Here's whats required for anyone interested
Oil 5w40 just over 4 litres
Filter 15209-00Q0F
Tools required
Flat screwdriver for removing undertray clips
10mm socket for same
An 8mm square removal tool for the sump nut
And I think it was a 27mm socket for the filter housing
Sent from my Mi A2 Lite using Tapatalk
Nice but, the sight of "made in France" and "Renault" made a bit of sick come up :sick:
K14 0.9ig-t
In that case you may be best pleased amused or not, that the whole thing is designed & built by Renault with badges engineered by Nissan.
I guess we are shy of one Nissan as it’s a Renault masquerading as a Nissan; possibly due to La Cost Cutter Carlos Grosn currently jailed on remand awaiting trial in Japan for fraud?
Quote : “Micra 0.9 IG-T 2017 Road Test ; The obvious comparison here is with the Clio, given the partnership between Renault and Nissan, especially as this Micra will be built by Renault in France”.
References; https://www.honestjohn.co.uk/road-tests/nissan/nissan-micra-09-ig-t-2017-road-test/
https://www.foxbusiness.com/business-leaders/carlos-ghosn-indicted-on-two-new-charges
Always look on the bright side of life as I guess the filter is made by cheap & cheerful lowest possible cost supplier Fram for Purflux with a Nissan engineered embossed badge label on the box at 3 times the normal Fram price?
Enjoy!
I'm pretty sure I seen a documentary about the K14 build and Renault had to really up the game to make it on their lines ,
So far it's build quality is as good as my 98 pulsar if not better
Filter 15209-00Q0F
Tools required
How do I remove the clips on the undertray, dont want to break them.
All the 1.5 diesel engines in Nissans are straight from the renault factory, all with renault on the filters even when bought from Nissan parts counter!!
