K12 problem
I have a 1.4 K12 that delveloped a misfire yesterday. I have used a bit today and the engine check light has just came on. Anything i can check for before getting ripped off by dealers.
Scott
Your best bet Scott is if someone on here from your area has a fault code reader and can read the codes for you. Failing that, most small local garages have universal fault readers and might point you in the right direction :).
Just had car checked by local garage (not dealer). Oxygen sensor dirty. He has cleaned it and light has gone out and car running smoth again(Y)
