CMF_GarethW
» CMF MemberIs there any cheap and cheerful mods i can do to my k11 for a bit more performance?
thanks for your help i will try this outmycra WROTE:
"ok this is what i did, there's a mesh that sits over the throttle body to prevent anything big go in. make another one yourself or find one at the wreckers... look for that material similar in the air filter(i used dried wet towels from work) and jam in the middle like a sandwich between the mesh. there's your filter, then get some memory hose from autobarn install and stick it pointing straight at the front. <BR><BR>On mine using the Apexi G-Meter, that makes a 6-7ps difference, only problem is changing or cleaning the filter material often (which is handy 4me cuz i got 1000 wet towel form work lol)<BR><BR>also index and gap ur plugs makes an extra 1kw more with Iridium. you could also try those little turbo spinning fan they have on ebay.
mycra WROTE:
"you could also try those little turbo spinning fan they have on ebay.
deNs WROTE:
"</div>
For the love of god, do not waste your money on that ****; it does nothing. Iridium plugs are fine to get if you are that fussed but unless you're that really that keen to get the extended life out of your plugs, I don't see the attraction - it's just another wank really.
Also, why are you suggesting to people to use dried towels as filter paper? Just use/make a cold air intake using a pod if you're that keen for extra power - if you're making it, it can be done for extremely cheap if you're creative in how you go about it.
Also a G-meter can in no way accurately measure horsepower. Put it on a dyno, come back and show the difference or there's no point even mentioning figures.
Sigh.
---dens
MacGillaZ WROTE:
"What I think Dens is getting to is the fact that a) if you can afford to spend money on a stroker kit, you can afford a $15 filter which is likely to perform better than your ghetto Filter sock. If you had put a bellmouth on the end of the TB then I could possibly understand your logic, but yeah, tis your engine thats potentially injesting more than just air, nom nom nom ...
Okay, your whole swirl pot and 10K reference on a B16a2, makes me scratch/shake my head! I agree with your point that inducing swirl into an intake will help with the mixing of the atomised fuel droplets in the air, but your theory that it will still help once an engine is turbo-charged (don't know what else the 20psi reference is for then!) is wrong. How laminar do you think the air coming out of a turbo is? You think you can induce MORE swirl or that your swirl generator isn't going to increase back pressure/restriction in your intake? Turbo tech is a different kettle of fish to NA tech ...
Please also never think/quote dynos are 100% accurate, nor the fact that many 'forums' = good. Dyno time is a good way of showing that things are improving and tuning to make good of these improvements. Unless the dyno-operator spends the extended time calibrating the dyno to your extact ratios, is it going to give anything but a nice set of reference numbers.
You want to use times/gps measurements?
You're better off doing timed runs of WOT pulls in say 4th/5th gear up either Wellington/Ferntree Gully rd hills, where by the ability of your setup to breath will be self evident, and the loading is reliable & repeatable.
For the sake of my curiosity, how much did your stroker B16 make on chasers dyno in the end?
