K11 nearly stalling when idles at traffic lights
CMF_DarthPunk
Hello,
My K11 nearly stalls when idleing. It is ok when driving but it sems the engine is not getting enough fuel when stationary. I hav echecked teh fuekl pump an it is ok and also checked the fuel filter and its ok. I had someone say it could be the idle model? Does anyone think what it could be?
CMF_mycra
if that didn't milk it.. check for vacuum leaks. idle can be bumped up if needed(plastic allen screw behind tb).
when you go and put the idle motor back be VERY care full with the O ring and don't use degreaser. 'Go Contact' cleaner would be best and also for the A/F/M.
