K11 CG10DE (1999 distributor version) help...
Morning all,
So I have been given a free Micra K11... Thanks Nanna....
It's a 1 litre engine and I have acquired some bits to turbo charge it, which for a laugh I would like to do. If this goes reasonably well then I might invest a little bit more time into the chassis and engine... You never know.
My question at the moment... Injectors? I'm looking for 4 x GA16 injectors? It's a small CT9 turbo from a Galanza and I will be fabricating all the pipe work myself.
I hear double stacking the head gasket will reduce compression ratio? Is this simply a drop two on another and bold down?
Engine timing? Who? How? Cheaply?
Any advice or conversations would be appreciated and if you want to PM me also that's fine.
Thanks all!
My cg10de 6psi
