Irratic lights and low power k12 1.0
Hello,
I have been having the fault when you only get part throttle/low power when the sidelights are on....I have changed all the rear sidelights/brake lights and indicator bulbs to good quality ones and I sill have Low power/ part throttle when the lights are on.
Also when I indicate right , the brake light and reg plate light flash on/off ...
And when braking , the o/s rear indicator flashes.
Any ideas !?!? Need this poor we car for work and the winter mornings are a struggle ....
Car is a 3door 54 plate 1.0
All help/ideas appreciated !!!
My lights used to flicker with indicators,have you checked your battery and alternator outputs. Mine was a weak battery when i had this issue
Check the earths, there should be one above box going to bulk head, one on each inner front wing behind head light, rear d post or quarter panel and one under dash top behind radio
