Instrument Cluster For K11 Micra
Can anybody tell me if the instrument cluster from a K11 1.3 will fit a K11 1.0?
I know it will physically fit, but are the wiring looms the same and will there be a connection available on mine (1.0) for the Revcounter?
There are 2 type of connections for the gauges.
This one:
And this one:
The difference is the speedo cable. If you have a analog one you need a analog one with a rev counter. If you have the digital one you need a digital one with rev counter. It depends on the year but its best to just check the backside. As long as the type is the same it will work. The wiring is the same.
For the rev wiring being there it depends. If youre lucky its there. If youre not then you have to pull the wire from the dizzy or ecu. If you do a search here you'll find info about this.
Thanks - I have the cluster now which is as your second pic, but have not opened up my dash yet.
Mine is def digital so should be ok but (always!) until I see what's behind I won't know for def.
Will post again when I try fitting.
