Inmobliser problem
my son has a 2003 keyless start micra which when starting turns over fires up but cuts out straight away you can tell its going to fire up ok you can feel the brake pedal go down further a bit, you need to press brake pedal when starting car as well as turning switch some times it takes up to ten times to fire up any ideas thanks in advance
