how do i go about removing springs so i can cut coils?
For the fronts you might need spring compressors? I never removed springs.
Remove the leg, use spring compressors, undo top nut and remove spring.
For the rear I undone the shock then got someone to stand on the rear hub pulling it down just enough to wiggle the rear spring free.
