Help
CMF_White Knight
The wiring up of the Autronic is going great. One problem.
With the new harness we are not sure what wires go where into the distributor. There is a 5 pin plug and these wires then feed the coil pack, crank angle sensor and the ignition module inside the dist.
Anyone got any clues as hate to wire it up.
Seano does it show any info in the Workshop manual as to which pin feeds what??
Everything going just great. New throttle body now all done as rest of plumbing, went easier than thought, new harness in so its now just a matter of wiring up!!
