yeah it`s a ###### of a job basically to do it properly
take out the rear lights two bolts each plus one clip righ behind them
then jack up the back end and take both wheels off and
the arch liners out to get to
the aligning bolts you can do it without but scrapes your hands up loads
then it`s easy you have one 10mm bolt to either side that was behind the rear lights
four clips i think along the bottom edge
and the two aligning bolts inside the arch think these are 10mm aswell
and pop the numberplate light out and unplug that
may i ask why you want to take it off ?
