Headunit still has power even when the ignition is off
Trung
Founding Member
Just bought a Micra and the previous owner who fitted a headunit has cut and re-wired the original wires without having to use an ISO adaptor.
When the car ignition is off I can still use the headunit or left on stand-by which isn't right.
Which wires do I have to re-wire back?
Jusat bought a Micra - hope the civic is not dead!
Haynes says that you need to swap red and black (constant power) with the blue and black wire (switched power).
Hope this helps :)
Craig
All sorted, the ign and 12v was touching each other so I used a tape to seperate them.
The Civic-R is still live and kicking, just using the Micra to commute to work ;)
