Headliner removal
Hi,
Anyone removed the headliner and installed it back again succesfully? I've been installing some sound deadening material into doors and rear of the car and was wondering how to remove the headliner and put something there as well.
Copied from here
first thing you need to do is unbolt and remove the back seat, then remove the rear sail panels by the back window. then slide the front seatbelts down to the lowest position. the panels around the seatbelt just pull off. then remove the grab handles on the headliner and the sun-visors and rear view mirror. use a screw driver to remove the cover over the mirror and there are screws underneath also remove the panels that cover the front pillars. open the sunroof all the way and you'll see 2 clips on each side of the sunroof use a screwdriver to remove them.now your ready to start removing the headliner. in the back the headliner is held in with some snaps. just grab on by the rear window and pull down. the area around the sunroof is held on with some type of velcro. just pull and it will come down. once you have the front and the back part down the headliner will still be held in place by the a sliding clip in the middle. just slide the headliner forward and it should now be free.
