jamier2007 Ex. Club Member Aug 1, 2012 #1 What is the limit you can skim a k11 head thats got 1.0 pistons? Obviously it wil have high compression anyway but every little helps
OP OP jamier2007 Ex. Club Member Aug 1, 2012 #3 That would be awesome. So no issues with valves hitting or something like that?
frank Club Member Aug 1, 2012 #4 jamier2007 said: That would be awesome. So no issues with valves hitting or something like that? Click to expand... nah. i,ve just fitted a 2mm skimmed head with weld filled chambers too (and 1.0 pistons)
OP OP jamier2007 Ex. Club Member Aug 2, 2012 #6 Also are there any problems with the timing chain being slack?
frank Club Member Aug 2, 2012 #7 jamier2007 said: What compression ratio does taking 2mm off give you? Click to expand... mine,s a 1.0 atm, so about 11:1 i guess jamier2007 said: Also are there any problems with the timing chain being slack? Click to expand... yes, if the chain is half worn the lower tensioner will be fully extended
