I have had this for a month or so now,... on cold start and running before engine gets up to temp, my gear changing is fine,no trouble at all BUT, once my engine is up and running at temp, it becomes hard to get into any gear, i really have to push it hard to get it in to gear,its as though the clutch isnt depressed. sometimes i have to lift the clutch and try again or it give the grinding sound as i am trying to change gear. also, when u put it in reverse, it always gives that kind of clonking/grind sound. but once cooled down or cold start, is fine,not trouble at all.
Any ideas people?, i thought clutch may need doing but its not all the time, so cant be that. also though it may be the linkage but that would happen all the time i would have thought, not just when running at temp.
