The only reason i said that was because ive got two identical amps, one powering the front and one doing the rears. The gain on the rears is higher (by accident) than the fronts. If the headunit is set smack bang centre, the rear speakers are alot louder than the fronts
Also, the gain control on my Dj Mixer increases or decreases the volume depending which way its set. You can use it in combination with the channel volume to get the perfect sound match - in volume - to the other channel
