FS: Damaged CG13DE Black Top Engine
CMF_warpz0r
Hi all
the engine is damaged but to an unknown extent.
it had low compression so most likely the head is in good condition and the block would be stuffed...
it would be ideal for someone wanting a spare block or spare head.. dont mind seperating...
im located in sydney
CMF_Yom
Ah so it turns out your engine was deadz0r!
Ah well. Its the luck of the draw.
I'd be interested in purchsing the afm/throttle body. How much do you want for it? Do you know if it worked OK?
