nex
my gas kit uses the dizzy/tacho wire for the auto shut-off on the soleniod,s in the tank (if the engine cuts out)
nex
yeh, it,s a pulse, but i would have thought it,ll light a bulb (akin to 240v AC @50htz)
It primes when the ign is first turned on, then only when the engine is running.
ah ok good thinking, but there must be two signals to the fuel pump, one comes from some kind of timer, is that in the ECU? and the second is obviously from the ECU to keep up with the demand of fuel,
if the engine stalls does that instantly cut the fuel pump too?
and at what point does the fuel pump start?
i assume that the point of priming the system before you start the car is so that all power can be used to start the car, and get it started quickly
if i can take the signal from just the ECU instead of what ever timer there is then i wouldn't get my "little dash light" coming on and saying the engine is running when the fuel pump is just priming
No, its one.
Yes
When a crank angle signal is detected.
Its to get pressure in the fuel system to push out any air before the cranking happens.
Yes it would initially, but hey, that would just show that the bulb works.
Ed
haha very good point but that will also come on if the engine is knackered even if its running...
is there anything that is 100% just when the engine is running or not?
Um no don't do that at all.
How many answers do you need to this question!!!! Take the ECU light or fuel pump signal, surely that will do?
Sound reasoning, however one flaw - you cannot knacker a cg13!
Why does it need to be 'so perfect'?
fair enough, i agree with that, but the dizzy signal depends on the condition of the dizzy and engine light depends on the condition of the engine and if theres a fault etc and fuel pump runs when the engine is not running, im not 100% sure but id say the pump has a constant supply from when the ignition is on and there is a pressure swith within the pump that shuts the pump down and not necessarly turns off the signal.
so looking at the options he has to get an engine running signal, its either dizzy or altenator. and id go altenator as it will be easier imo
The pump is ONE HUNDRED % controlled by the ECU. Simple as that.
The engine can still run with check light output on - so thats no good.
This thread is getting a little pointless. The fuel pump is directly related to crank signal, which is related to engine turning - obviously. So use that and its either on or off.
If the alternator starts to fail the voltage at the bulb can vary all over the place.
Ed
It would keep a contstant pressure up, surely?
The ECU pulls the relay to ground. Which then switches a live to the pump.
cool so i can pick up a negative, or ground signal from the ECU and attach it to a relay with a constant 12v+
that actually works out perfectly
if the ecu is capable of supplying the extra current ? (ie 2 relays)
can,t you run your relay from the high current side of the fuel relay ?
