Engine cuts out after increasing revs
CMF_How_P
Hi
I'm having some engine troubles and don't know a great deal about mechanics, but always willing to learn.
Basically, the engine will ignite fine and will run idle ok, although it does shake irregularly and misfire occasionally.
When the Revs are increased, when stationary or moving, the engine will run for a few minutes but then chug, lose power and then die. It will then not turn back on for a few minutes, but when it does, the same thing will happen.
Ive been told it might be something to do the spark plug coil. Any ideas what to do and how to check where the problem is coming from?
CMF_will9301
could be the coil mate but if its prefascelift i dont think it has a coil.... but maybe the ignition timing is out not 100% sure but a pointer eh
CMF_How_P
Sorry I probably should have said - it is a 1991 K11 Micra.
I have checked fuel filter, air filter, spark plugs and resoldered the throttle body.
