CMF_Bob Flemming
» CMF MemberHi. Please go easy as this is my first post and I desperately need your help. I have read so many pages and suggested solutions that I'm only posting now as I'm out of ideas.
I purchased a 1999 K11 Micra as a "sold as seen" on Ebay and have had nothing but trouble with it. The engine will run fine one minute giving good power and response and then it will suddenly "chug" or "judder" - skipping from having power to having none what so ever. When it does this it really struggles to tick over and will usually stall. There seems to be no common cause though - sometimes its hot, sometimes cold. Sometimes it won't even tick over at initial start up. Other times it will run fine for an entire journey or 30+ miles.
I have already replaced the following components in an attempt to remedy the fault - HT Leads, Dizzy cap (x2), Dizzy (x3), complete throttle body change including three combinations of sensors (Air Flow Meter, Throttle Potentiometer etc), air filter and battery. I have also checked the fuel pump is in full working order.
Engine management light does not illuminate when the fault occurs, only if the engine stalls.
Any suggestions? You help and advice is humbly accepted.
