drills
#1
what size drills to drill out welding points to remove the cross member and are they specials, will have to remove and replace cross member soon,cheers from an oldun,plus is hard to get at remove front bumper then off i go is that right .thanks
#2
I have used one of these, its 8mm special drill. But I think you can use normal drill 6 or 8mm
Изпратено от моят HUAWEI VNS-L21 с помощта на Tapatalk
