Just in case it might help somebody.
The remote door locking key failed the other day. Unlocking worked, locking did not.
Took it apart and found that the tiny micro switch had come loose and was floating around under the soft plastic cover.
Spot of Superglue to stick it back on to the pcb, then used soldering iron to remake the two connections.
Works perfectly.
Works perfectly.
