Do I need spacers?
You won't need spacers mate. Will look fine with the standard setup. Good to see that you've gone for the Konis tho.
Will look good with the 14's to!
Titch :kungfu:
As Titch said you would not be needing spacers, the wheels will look fine just were they are.
If the front wheels are push out to far on a K11 they will hit the wing. After 7" wide alloys you start to find problems with the side of the alloy/tyre making contact agaist the inside of the wing.
Mike
