constant live
needing a constant live for my g.fs cd player. gonna hopefully paint the centre consol at the weekend so would like to find this and wire the cd player up correctly at the same time. thanx chaps
run a wire from the +ve terminal on the battery, then ground the wire on the chassis of the car.
Connect the in line fuse somewhere in the wire between the battery and thing you're powering :)
To ground it connect the black wire to the chassis of the car - usually a nut or bolt or something.
closer to the battery is better though (for the in-line fuse)
