clutch
has anyone converted a k11 micra clutch from cable to hydraulic?
im looking at swapping a 01 coil on plug cg10 engine into a mini,
my mini already has a wilwood pedal box set up for three master cylinders,
two for the brakes and one for the clutch
I don't want to change this pedal box out because ive already spent a lot of money
and my brakes are set already
so im trying to see if anyone has converted the clutch over
do you know how much throw the clutch needs?
I guess I could go out and measure the clutch on my 96 k11 right now and see whats up
i would place it about 40mm from the fulcrum i guess
I'm looking at picking up this drivetrain this weekend, it has 19k miles on it, and comes with a subframe and axles, and a full micra loom and a remapped ecu, and cluster, fuel pump/ tank
The set up was already in a mini for 3 mot's
The only thing about the fuel system is my car is already setup with a fuel cell and -6 an steel braided fuel line, so I need to figure out how to convert those lines to the micra fuel rail
500 quid for the setup
