My micra has 53mm of play before the brakes bite and I also have brand new discs and pads. Brakes feel solid, they work effectively so I'm not fussed about the pedal free play. My accelerator pedal also has about 25mm off free play. If the brake operation is fine then the issue is likely to be with the pedal, not the braking system. Air in the system could cause something similar but it would feel spongy and unresponsive.
I have a peugeot partner and citroen picasso with the same pedal feel. The only vehicle we have that has immense brake pedal feel is the jeep cherokee.[
thanks for the help & info max. its our 1st micra. you have been very helpful. cheers m8. steve.
