Binding Front Calipier
when u release the brake pedal the front calipier isn't withdrawing from the disc, so pads wear quickley and and alloys constantly covered in brake dust:doh:
You can re-con it with new seals, but guess that the only place to get the kit from would be Nissan, ask in there
have you tried freeing it off by pushing it in (big pair of pliars are needed) and then pumping the pedal slowly (another person would be good for this) and keep trying that it might start to free off
also are you sure its not the pads sticking in the guides? if so get a screwdriver or wire brush and clean up the guides then use copper slip in the pad edges that come in to contact with the guides
