Belts
CMF_Yom
Hi.
Well it seems ATF fluid from my power steering doesnt quite lubricate rubber belts the way it is meant to work in my power steering. :p
I am up for new belts because of this.
So I figured I'd find out what the model numbers of the micra belts are and the size measurements of them so I can fit some Goodyear Gatorback belts (long lasting for the win).
Post up if you have correct belt model numbers and also sizes.
Power steering (incl. waterpump) belt = Bosch 4PK760
Waterpump belt (no power steer) = 3PK630 (you might want to double check this one, could be a 4 rib (4PK***) size)
Alternator (no aircon) belt = Bosch 3PK915
Alternator + aircon belt = Bosch 6PK0955
Cheers!
CMF_Alex_B
Heres all the different setups, no part numbers though, takes too long to look up :p
Alex
CMF_Alex_B
93-98 Micra
W/O AIRCON/POWER STEERING
11720-1F700 Alternator Belt
11720-1F710 Water Pump Belt
WITH POWER STEERING
11950-41B02 Water Pump Belt
WITH AIRCON
11920-41B02 Alternator Belt
WITH AIRCON/POWER STEERING
Alex
CMF_Yom
UUUPDATE!
WARNING: BOSCH IS INCORRECT.
If you have power steering, to repalce that belt you need a 4PK760 (providing it is a standard nissan power steer system). The bosch recommended 3PK630 is just WRONG.
