BATTERY!
Allo everyone,
Just wondering what the process is to changing a K11 Micra 1.0 S battery?...
I've just come back from the battlecruiser and the battery light was lit up and took a little bit to start... Fancy getting another battery just to cover my /\rse due to this cold weather...
Cheers for replies lads, when I said it took a little bit to start, took a little grunt... reckon it's worth just getting a recon alternator and getting it on the motor?
Do a charge test measure batt voltage with no load so no head lights stereo wipers etc then turn everything on from air con to demister and check should be around 14.2-14.6 v
