battery for k11
hi,
ive recently got a 1.3 k11 micra and the batterys completely dead.
im looking to get a decent ICE install.. either a single or twin subs, rear 6x9s, 2 7" screens and then probably a decent set of interior neons.
what i need to know is whether or not the standard battery, should i buy one which is the same size as the normal one which seems really small to me, would be capable of powering all of the above, or should I buy a larger one and then alter the housing for the battery.
thank you.
The standard battery is fine for the standard alternator.
I ran 220w spotlights, one 4 channel and one 2 channel amp off my standard battery and it worked fine, the lights did dim a bit at full volume while idling though.
