trike micra Jul 7, 2020 #1 The radiator on the autos cool the gearbox as well as the engine, is it an oil cooling system or is it water?
OP OP trike micra Jul 8, 2020 #3 frank said: heat exchanger pipe embedded in the lower plastic header iirc Click to expand... So running a separate oil cooler similar to a motorcycle cooler might work? looking at building another trike to my own design, a separate radiator setup is looking like the easiest way of cooling.
