auto engine swap ???
Hi everyone i just got this micra for free its a 1.0lt auto i believe it would be a lot of work to put manual gearbox in so what options do i have for auto also has anyone tuned up an auto thanks
The automatic does drain power a bit but it’s not too bad, many of the engine mods can be used but it will cause wear quicker If you abuse it.
the cvt gearbox takes a bit of getting used to, allow it to Rev up then back off a bit seems to be the best way.
we went for the weight reduction route, the trike is 500 kg.
